¡ö ²úÆ·¹æ¸ñ |
ϵͳ System |
´¦ÀíÆ÷ Processor |
Intel® 4th Gen. Core™ i3/i5/i7, Pentium®, Celeron® processor, LGA1150 Socket |
оƬ Chipset |
Intel® H81 Chipset |
ÄÚ´æ Memory |
DDR3-1333/1600MHz, 2 x DIMM Slot, up to 16GB |
´æ´¢ Storage |
2 x SATA 2.0, 2 x SATA 3.0 |
ͼÐÎ Graphics |
Intel® HD Graphics, dual display |
²Ù×÷ϵͳ OS |
Windows XP (limited function)/7/8/10, Linux |
Íⲿ½Ó¿Ú Rear I/O |
Íø¿Ú Ethernet |
2 x RJ45 Realtek® RTL8111G-CG GbE (10/100/1000 Mbps) |
񙮵 Audio |
1 x Line-in, 1 x Line-out, 1 x Mic-in |
ÏÔʾ Video |
1 x VGA: max resolution up to 1920 x 1200
1 x HDMI: max resolution up to 2560 x 1600
1 x DVI-D: max resolution up to 1920 x 1200 |
´®¿Ú COM |
1 x RS232 |
USB |
8 x USB 2.0, 2 x USB 3.0 |
°´Å¥ Button |
1 x Power Button, 1 x Reset Button |
ָʾµÆ LED |
1 x Power LED, 1 x HDD LED |
ÄÚ²¿½Ó¿Ú Internal I/O |
À©Õ¹½Ó¿Ú Expansion |
1 x PCIe X 16 Slot, 1 x PCIe X 1 Slot, 2 x PCI Slot |
·çÉÈ FAN |
1 x CPU Fan , 1 x System Fan |
GPIO |
1 x 8-bit GPIO (optional) |
USB |
4 x USB 2.0 |
´®¿Ú COM |
5 x RS232 |
»·¾³ Environment |
²Ù×÷ÎÂ¶È Operation Temp. |
0¡æ ~ 40¡æ |
´æ´¢ÎÂ¶È Storage Temp. |
-20¡æ ~ 60¡æ |
ʪ¶È Relative Humidity |
5% ~ 95%, ·ÇÄý½á״̬ Non-condensing |
µçÔ´ Power |
µçÔ´ÊäÈë Power Input |
100~240V(AC) |
µçÔ´¹¦ºÄ Power Watt |
300W |
»ú¹¹ Mechanical |
Íâ¹Û Housing |
SGCC |
³ß´ç Dimension |
455(L) x 427(W) x 178(H)mm |
ÖØÁ¿ Weight |
15kg(Ô¼) |
°²×°·½Ê½ Mounting |
»ú¹ñʽ (Rack-Mount) |
ÈÏÖ¤ Certification |
°²¹æÈÏÖ¤ Safety Certification |
CCC |
