²úÆ·¹æ¸ñ Specification |
ϵͳ System |
´¦ÀíÆ÷ Processor |
Intel® Bay Trail Celeron® J1900 processor (2.00 GHz) |
ÄÚ´æ Memory |
1 x DDR3L 1333 SODIMM Slot, up to 8GB |
´æ´¢ Storage |
1 x 2.5" Drive Bay for SATA HDD/SSD,
1 x M.2 2242 (support SSD only)/1 x mSATA£¬ |
ͼÐÎ Graphics |
Intel® HD Graphics for Intel® Atom® Processor Z3700 Series |
²Ù×÷ϵͳ OS |
Windows 7/8.1/10, Linux |
¿´ÃŹ·¶¨Ê±Æ÷ Watchdog Timer |
Programmable 255 levels timer interval£¬from 1~255 sec/min |
´¥ÃþÆÁ Touchscreen |
´¥ÃþÆÁ Touch Type |
10µãͶÉäʽµçÈÝÆÁ P-cap Multi-Touch |
´¥»÷ Touch |
35,000,000 times |
ÏÔʾÆÁ Display |
³ß´ç Size |
21.5 inch |
·Ö±æÂÊ Resolution |
1920 x 1080 |
ÆÁÄ»¿í¸ß±È Ratio |
16:9 |
ÁÁ¶È Brightness |
250nits |
¿ÉÊÓÇø Active Area |
476.064mm x 267.786mm |
LCD³ß´ç Dimension |
495.6(W) x 292.2(H) x 10.7(D)mm |
¿ÉÊÓ½Ç Viewing Angle |
CR£¾10, 89°(H)/89°(V) ; |
¶Ô±È¶È Contrast Ratio |
1000 |
É«Éî Display Color |
16.7M |
ÏñËØ Pixel Pitch |
0.24795 (H) x 0.24795 (V) |
±³¹â Backlight |
LED Backlight |
±³¹âÊÙÃü Backlight Lifetime |
30000Hrs |
¹¦ºÄ Power Consumption |
10.4W |
»ú¹¹ Mechanical |
Ç°¿ò Front Panel |
ÂÁ Aluminum |
ÂÁ¼· Heat-Sink |
ÂÁ Aluminum |
µ×°å Rear Cover |
Ìú SECC |
°²×°·½Ê½ Mounting |
Panel Mount, Wall and VESA-mount (75 x 75mm) |
³ß´ç Dimension |
528.2 X 321.9 X 66mm |
½¨Ò鿪¿×³ß´çCut Out |
520.2 x 313.9mm |
ÖØÁ¿ Weight |
7.2Kg |
Íⲿ½Ó¿Ú External I/O |
´®¿Ú COM |
2 x RS232/RS422/RS485(COM1& COM2)¡¢
2 x RS232(COM3 & COM4)¡¢ |
USB |
3 x USB 2.0, 1 x USB 3.0 |
Íø¿Ú Ethernet |
2 x Intel® I211AT GbE (10/100/1000 Mbps) |
ÏÔʾ Video |
1 x HDMI (up to 1920 x 1200) |
Ô¶³Ì¿ª¹Ø Remote ON-OFF |
1 x Remote ON-OFF |
µçÔ´ÊäÈë Power Input |
1 x Power Connector (2P Phoenix) |
񙮵 Audio |
1 x Line-out, 1 x Mic-in |
ÄÚ²¿½Ó¿Ú Internal I/O |
À©Õ¹½Ó¿Ú Expansion |
1 x full-size Mini-PCIe Slot (Co-Lay with M.2_SSD)
1 x M.2_SSD Slot(1 x SSD only)
1 x M.2_Wifi Slot (Wifi only)
1 x SIM Card Slot |
µçÔ´ Power |
9~36V DC |
ÊÊÅäÆ÷ Adapter |
AC-DC, 12V@5A, 60W |
»·¾³ Environment |
²Ù×÷ÎÂ¶È Operation Temp. |
-10¡æ ~ 50¡æ (SSD), 0¡æ ~ 40¡æ (HDD) |
´æ´¢ÎÂ¶È Storage Temp. |
-40¡æ ~ 70¡æ |
ʪ¶È Relative Humidity |
5% ~ 95%, ·ÇÄý½á״̬ Non-condensing |
Ëæ»úÕñ¶¯ Random Vibration |
5~500Hz, 1Grms (HDD)operation, 5~500Hz, 2Grms (SSD)operation |
ÕýÏÒÕñ¶¯ Sine Vibration |
5~500Hz, 2G Non-operation |
»úе³å»÷ Shock |
10g 11ms operation, 30g 11ms Non-operation |
ÈÏÖ¤ Certification |
°²¹æÈÏÖ¤Safety Certification |
CCC |
