²úÆ·¹æ¸ñ Specification |
ϵͳ System |
´¦ÀíÆ÷ Processor |
Intel® Bay Trail Celeron® J1900 processor (2.00 GHz) |
ÄÚ´æ Memory |
1 x DDR3L 1333 SODIMM Slot, up to 8GB |
´æ´¢ Storage |
1 x mSATA |
ͼÐÎ Graphics |
Intel® HD Graphics for Intel® Atom® Processor Z3700 Series |
²Ù×÷ϵͳ OS |
Windows 7/8.1/10, Linux |
´¥ÃþÆÁ Touchscreen |
´¥ÃþÆÁ Touch Type |
ȫƽÃæÎåÏßµç×è´¥ÃþÆÁ 5-Wire Resistive Touch |
´¥»÷ Touch |
35,000,000 times |
ÏÔʾÆÁ Display |
³ß´ç Size |
10.4 inch |
·Ö±æÂÊ Resolution |
800(H) x 600(V) |
ÆÁÄ»¿í¸ß±È Ratio |
4:3 |
ÁÁ¶È Brightness |
400 nits |
¿ÉÊÓÇø Active Area |
211.2(H) x 158.4(V)mm |
LCD³ß´ç Dimension |
243 (W) x 184 (H) x 6.5 (D)mm |
¿ÉÊÓ½Ç Viewing Angle |
60°(T)/70°(B) 70°(L)/70°(R) |
¶Ô±È¶È Contrast Ratio |
500 |
É«Éî Display Color |
16.2M/262K |
ÏñËØ Pixel Pitch |
0.264(H) x 0.264 (V) |
±³¹â Backlight |
LED Backlight |
±³¹âÊÙÃü Backlight Lifetime |
50000Hrs |
¹¦ºÄ Power Consumption |
3.72W |
»ú¹¹ Mechanical |
Ç°¿ò Front Panel |
ÂÁ Aluminum |
ÂÁ¼· Heat-Sink |
ÂÁ Aluminum |
µ×°å Rear Cover |
Ìú SECC |
°²×°·½Ê½ Mounting |
Panel Mount, Wall and VESA-mount (75 x 75mm) |
³ß´ç Dimension |
272.9(W) x 217.9(H) x 60(D)mm |
¿ª¿×³ß´ç Cut Out |
264.9 x 209.9mm |
ÖØÁ¿ Weight |
2.6kg |
Íⲿ½Ó¿Ú External I/O |
´®¿Ú COM |
2 x RS232 (COM1~2) |
USB |
1 x USB 2.0, 1 x USB 3.0 |
Íø¿Ú Ethernet |
2 x Realtek® 8111F GbE (10/100/1000 Mbps) |
ÏÔʾ Video |
1 x VGA (up to 2560 x 1600) |
µçÔ´ÊäÈë Power Input |
1 x Power Connector (2P Phoenix) |
ÄÚ²¿½Ó¿Ú Internal I/O |
À©Õ¹½Ó¿Ú Expansion |
1 x full-size Mini-PCIe Slot (1 x Wifi/3G/4G), 1 x SIM Card Slot |
µçÔ´ Power |
12V DC |
ÊÊÅäÆ÷ Adapter |
AC-DC, 12V@5A, 60W |
»·¾³ Environment |
²Ù×÷ÎÂ¶È Operation Temp. |
-10¡æ ~ 60¡æ (SSD) |
´æ´¢ÎÂ¶È Storage Temp. |
-40¡æ ~ 70¡æ |
ʪ¶È Relative Humidity |
5% ~ 95%, Non-condensing |
Ëæ»úÕñ¶¯ Random Vibration |
5~500Hz, 2Grms (SSD)operation |
ÕýÏÒÕñ¶¯ Sine Vibration |
5~500Hz, 2G Non-operation |
»úе³å»÷ Shock |
10g 11ms operation, 30g 11ms Non-operation |
ÈÏÖ¤ Certification |
°²¹æÈÏÖ¤ Safety Certification |
CCC |
