Introduction
The PXIS-2558T is ADLINKs new-generation PXI chassis equipped with advanced features and functionalities. Its worlds first bench-top PXI chassis come with a 8.4" LCD touch panel. The PXIS-2558T also boasts of wider operating temperature range, lower operating noise, and robust system build. The 8.4" LCD touch panel, which support 800x600 resolution, is the distinguishing feature of PXIS-2558T. Combined with the 6.4 kg light-weight construction, the PXIS-2558T delivers great portability for your PXI-based applications. Additionally, the PXIS-2558T has plenty of advanced features, including 0~55¡ãC extended operation temperature range, 41.6 dBA ultra-low operation noise, and innovative intelligent chassis management. Its 350 W industrial-grade power supply delivers reliable power to your PXI system. With the advanced features and considerate design, PXIS-2558T is your best choices of PXI platform for test and measurement applications. |
