Introduction
ADLINK PXI-3920 is a next-generation PXI™ embedded controller designed for hybrid PXI-based testing systems. It provides plenty of interfaces, including GPIB, USB and COM ports, for connecting and controlling instruments. In addition, the PXI-3920 is the first PXI controller come with dual-Gigabit Ethernet ports for controlling next-generation LXI instruments. The PXI-3920 is cautiously designed to provide maximal robustness. It has cable-free mechanical construction and is extremely durable. The CPU and memory chips are soldered on the PCB to increase reliability in shock and vibration prone environments. The alumni-copper composite heat sink helps to disperse heat uniformly to maintain a stable operating temperature. Combining a variety of instrument control interfaces and reliable mechanical and electronic design, ADLINK PXI-3920 is well endowed to meet the needs of your hybrid PXI-based testing systems. |
