²úÆ·Ãû³Æ£º
Embedded PC ACX430
ÐÍ ºÅ£º
ACX430
±ØÉý
Supports Intel® Core 2 Duo Processor and Q965 / GME965 Chipset
Scalable with more Mini-ITX Options
Default onboard VGA, LAN, TPM |
Default 5.1+2-CH Audio, 6W AMP |
1 x PCI / PCIe Slot, 1 x 2.5" HDD |
2 COM (5V/12V), 6 USB |
Built-in 200W PSU & Power Cable Fastener |
PCI-E x16 Slot Supports ADD2 HDMI / VGA / DVI |
Wall / Desk Mount |
Specifications
Expansion |
Add-on Card |
1 x PCIe / PCI Full-height / half-length slot |
Hard Drive Bay |
1 x 2.5" HDD (Internal, IDE/SATA) |
SSD |
1 x Type I/II CF slot on bottom |
External I/O |
Rear Panel |
Depends on system motherboard |
Front Panel |
1 x PWR SW, 2 x USB, 2 x LED (PWR/HDD) |
Optional Knock-out |
1 x COM |
Power Supply Unit |
Power Input |
100 ~240 V / 50 ~ 60 Hz (Adapter) |
Power Output |
200 W |
Mechanical & Environmental |
Operating Temperature |
0~40¡ãC (32~104¡ãF) |
Relative Humidity |
5 to 90% @ 40¡ãC (104¡ãF), non-condensing |
Relative Humidity |
I/O Shield |
Standard ATX I/O opening |
Mounting |
Desk / Wall (wall-mount bracket in option) |
Dimension (WxHxD) |
W248 x H103 x D260 mm W290 x H115 x D260 mm (w / bracket) |
Weight |
5.73 lbs / 2.6 Kgs |
