ÎÞ·çÉÈǶÈëʽPC UNO-1019 ÑлªUNO-1019´øPXA200MHZ, 64 MB SDRAM, 2xLAN, 4xCOM,1xCFµ¼¹ì°²×°µÄÎÞ·çÉÈǶÈëʽ¿ØÖÆÆ÷ ¸ÅÊö ÑлªUNO-1019ÊÇÒ»¸ö´øÓÐ2¸öÍø¿¨¡¢4¸ö´®¿ÚºÍ4¸öÊý×ÖÊäÈëÊä³ö¼°CompactFlash¿¨¡£Í¬Ê±Ëü»¹ÄÚÖÃWindows CE.NET OS£¬Ìṩ¶¨ÖƵÄÓ³ÏñÎļþ¡£´ËÍ⣬Ëü¿ÉÒÔÔÚ0-70ÉãÊ϶ÈÖ®¼ä½øÐвÙ×÷£¬¼ÓÉÏËûµÄÌå»ýСºÍ¼õÖØÉè¼Æ£¬¿ÉÒÔ±»°²×°ÔÚ½ô´ÕµÄ¹¤Òµ»·¾³ÖС£UNO-1019Ò²ÊÇÒ»¸öÔÚ¹¤ÒµÁìÓòÀï´«µÝͨÐÅ I/O¿ØÖƺÍÊý¾Ý¿âµÄÓÅÐãͨÐÅÍø¹Ø¡£ ÌØÐÔ °åÉϼ¯³ÉIntel®XScale PXA-255 200MHZ CPU£¬64 MB SDRAM£¬16 MB Flash 2¸öRS-232ºÍ2¸öRS-232/422/485 ´®¿Ú 2¸ö10/100 Mbps ÒÔÌ«Íø¿Ú 1¸öCompactFlash²å²Û 4¸ö DI/DO ͨµÀ 3¸ö¿É±à³Ì¿ØÖÆLED(Óû§×Ô¶¨Òå) ²ÉÓÃǶÈëʽWindows®CE.NET ²Ù×÷ϵͳ Ö§³ÖÔ¶³ÌÏÔʾ£¬·½±ãϵͳÅäÖà ÎÞ·çÉÈ£¬½ô´ÕºÍ¼ò±ãÉè¼Æ 0-70ºC¹¤×÷ÎÂ¶È Ö§³ÖDINµ¼¹ìºÍ±Ú¹Òʽ°²×° ´®¿Ú¸ôÀë±£»¤¿ÉÑ¡ ¹æ¸ñ Ò»°ã¹æ¸ñ ÈÏÖ¤ CE, FCC class ³ß´ç(W¡ÁD¡ÁH) 46¡Á162¡Á126 mm (1.8"¡Á6.4"¡Á5") Íâ¿Ç ABS+PC£¬´ø½áʵµÄ°²×°²¿¼þ °²×°£¨¿ÉÑ¡£© DIN-rail°²×°£¬±Ú¹Òʽ°²×° ¹¦ºÄ 8.5 W µçÔ´ÊäÈë 10 ~ 30 VDC (13 W), AT ¾»ÖØ 400 g ϵͳӲ¼þ CPU 32λIntel XScale PXA255 200MHz ÄÚ´æ 64 MB SDRAM ָʾµÆ µçÔ´¡¢´®¿Ú(Tx, Rx)£¬3¡ÁÓû§¶¨ÒåLED ´æ´¢ ¼¯³É16 MBÉÁ´æ ÆäËû ʵʱʱÖÓ£¬¿´ÃŹ·¶¨Ê±Æ÷ ϵͳÈí¼þ ²Ù×÷ϵͳ Windows CE.NET 4.2£¨Ô¤°²×°ÔÚÉÁ´æÖÐ) Ô¶³ÌÏÔʾ ÏÔʾÆ÷Ô¶³ÌÏÔʾ ͨѶ ´®¿Ú 2¡ÁRS-232, 2¡ÁRS-232/422/485£¬´øDB9½Ó¿Ú£¬×Ô¶¯RS-485Êý¾ÝÁ÷¿ØÖÆ ´®¿ÚËÙ¶È RS-232: 300 bps ~ 115.2 kbps RS-422/485: 300 bps ~ 921.6 kbps (×î´ó) LAN 2¡Á10/100Base-T RJ-45¶Ë¿Ú Êý×ÖÁ¿ÊäÈë/Êý×ÖÁ¿Êä³ö Êý×ÖÁ¿ÊäÈë 2¡ÁÊý×ÖÁ¿ÊäÈë ¸É½Óµã Âß¼Öµ0£º¿ªÂ· Âß¼Öµ1£º½ÓµØ ʪ½Óµã Âß¼Öµ0£º+3 V max Âß¼Öµ1£º+10 VDCµ½30VDC Êý×ÖÁ¿Êä³ö 2¡ÁÊý×ÖÁ¿Êä³ö ¼¯µç¼«¿ªÂ·30V 200 mA×î´ó¸ºÔØ£¬¹¦ºÄ450 mW »·¾³ ¹¤×÷ÎÂ¶È 0 ~ 70¡ãC (32 ~ 158¡ãF) ´æ·ÅÎÂ¶È -20 ~ 80¡ãC (-4 ~ 176¡ãF) ¹¤×÷ʪ¶È 20~95% (ÎÞÄý½á) ´æ·Åʪ¶È 0~95% (ÎÞÄý½á) ¶©»õÐÅÏ¢ UNO-1019ACE-A1E Intel XScale ǶÈëʽ¹¤Òµ¼¶¿ØÖÆÆ÷£¬´ø2 x LAN£¬4 x COM£¬CF¿¨£¬Windows CE.NET 4.2 ÑлªUNO-1019Êǽô´ÕÐÍ¡¢×°ÓÐDIN¹ìµÀÎÞ·çÉÈÉè¼ÆµÄ¹¤ÒµPC¡£ËûÃÇÒÔRISC´¦ÀíÆ÷ΪÌØÕ÷£¬¾ßÓÐ¿í·ºµÄ¹¤×÷ζȣ¨×î¸ßÖÁ70 ¡ãC £©¡£ÕâЩ¶¼ÊÇÊʺÏ×÷ΪͨÐÅ¿ØÖÆÆ÷ºÍ¹Ø¼üÈÎÎñ»·¾³ÖеÄÐÒéת»»Æ÷¡£
UNO-2052E ÑлªUNO-2052E AMD GX2-400 MHz´ø2xCAN, LAN,USB,RS-232µÄÎÞ·çÉÈǶÈëʽ¿ØÖÆÆ÷ ¸ÅÊö Ñлª UNO-2052E ÊÇÒ»¿îÌṩ CAN 2.0B Ë«½Ó¿Ú¡¢Êý×ÖÁ¿ I/O ºÍÈȵçżÊäÈëµÄ 586 µçÄÔƽ̨¡£ ÓÉÓÚ UNO-2052E ´øÓÐ CAN 2.0B ½Ó¿Ú£¬Òò´ËËüÊÇÓÃÓÚÆû³µÒµºÍºóÇÚÓ¦ÓõÄÀíÏë½â¾ö·½°¸¡£UNO-2052E ÄÚÖà Microsoft Windows CE ½â¾ö·½°¸£¬Ìṩ¶¨ÖƵÄÓ³ÏóÎļþ£¬´øÓÐÓÅ»¯¹ýµÄ°åÔØÉ豸Çý¶¯³ÌÐò¡£ Microsoft Windows CE ÊÇÒ»Ì×½ô´Õ¡¢¸ßЧµÄʵʱ²Ù×÷ϵͳ£¬ËüÊÇΪÎÞÓ²ÅÌÏÞÖƵÄǶÈëʽϵͳ¶øÉè¼ÆµÄ¡£Èç¹ûÒªÀ©Õ¹´æ´¢ÈÝÁ¿£¬UNO-2052E »¹¿ÉÒÔʹÓÃÑлª UNO Ó²ÅÌÀ©Õ¹Ì×¼þÀ©Õ¹Ò»¿éÍⲿ 2.5" Ó²ÅÌ¡£ À©Õ¹µÄÓ²ÅÌ¿ÉÓÃÀ´½øÐдóÅúÁ¿Êý¾Ý±¸·ÝºÍ°²×°Í¨Óà OS Èç Microsoft Windows ºÍ Linux OS.¼´Ê¹ÆäÄÚ²¿Ê¹ÓûúеʽӲÅÌ£¬ËüÒÀÈ»¾ßÓÐÁ¼ºÃµÄ¿¹ÕñÐÔÄÜ¡£(1 G) UNO-2052E ÊÇÒ»¿îÄܹ»Ëõ¶ÌÄúµÄÓ¦Óÿª·¢ÖÜÆÚ£¬²¢Ìṩ·á¸»µÄÍøÂç½Ó¿ÚÒÔÂú×ãÄú²»Í¬ÏîÄ¿ÐèÇóµÄÀíÏëµçÄÔƽ̨¡£ ÌØÐÔ °åÉϼ¯³É AMD GX2-400 MHz CPU£¬128/256 MB DDR DRAM Ìṩ 2 ¸ö CAN ½Ó¿Ú 1 ¸ö 10/100Base-T RJ-45 ¶Ë¿ÚºÍ 1 ¸ö USB ¶Ë¿Ú 1 ¸ö¿É±à³ÌÕï¶Ï LED ָʾµÆºÍ·äÃùÆ÷¡£ Windows ® CE .NET ½â¾ö·½°¸¡£ Ö§³Ö Windows® 2000/XP ºÍ Linux Çý¶¯³ÌÐò Ìṩ Windows® CE 5.0 Binary BSP ¹æ¸ñ Ò»°ã¹æ¸ñ ³ß´ç (WxDxH) 188.8 x 106.5 x 35.5 mm (7.5¡± ¡Á 4.2¡± ¡Á1.4¡±) ¹¦ºÄ 15 W (µäÐÍ) µçÔ´ÊäÈë ×îС 24 W (9~36 VDC) (ÀýÈç +24V @ 1 A) ÖØÁ¿ 0.8 kg OS Ö§³Ö Windows® 2000, Windows® CE .NET 5.0, Linux ϵͳӲ¼þ CPU AMD GX533-400 MHz ָʾµÆ µçÔ´ LED¡¢IDE LED£¬1 ¸ö¿É±à³ÌÕï¶Ï LED ºÍ 1 ¸ö·äÃùÆ÷ LED ¼üÅÌ/Êó±ê 1 x PS/2 ÄÚ´æ °åÉϼ¯³É 128/256 MB DDR DRAM ´æ´¢ ¹Ì̬µç×ÓÅÌ:1 ¸öÄÚ²¿ Type I/II CompactFlash®²å²Û Ó²ÅÌ: ÓÃÓÚÒ»¸ö 2.5" Ó²Å̵ÄÀ©Õ¹×é¼þ VGA DB15 ½Ó¿Ú ͨѶ CAN Ë«¸ôÀë CAN 2.0B ½Ó¿Ú¡£CAN ¿ØÖÆÆ÷£º SJA-1000 CAN ÊÕ·¢Æ÷£º 82C250 Êý×ÖÁ¿ÊäÈë ¹æ»®ÖÐ Êý×ÖÁ¿Êä³ö ¹æ»®ÖÐ LAN 1 ¸ö 10/100Base-T RJ-45 ¶Ë¿Ú ´®¿Ú 1 ¡Á ±ê×¼ RS-232 ´®¿ÚËÙ¶È RS-232£º 50 ~ 115.2 kbpsÈȵçżÊäÈë ¹æ»®ÖÐ ÊäÈ뷶Χ£º ¹æ»®ÖÐ USB ¶Ë¿Ú 1 ¸ö USB ¶Ë¿Ú£¬·ûºÏ OpenHCI Rev. 1.1 ¹æ¸ñ ¿´ÃŹ·¶¨Ê±Æ÷ ¿É±à³Ì¡£ »·¾³ ʪ¶È 95 % @ 40¡ã C£¨ÎÞÄý½á£©Èë¿Ú±£»¤ IP40 ¹¤×÷ÎÂ¶È -10 ~ 55¡ã (14 ~ 131¡ã F) ³å»÷±£»¤ IEC 68 2-27 CompactFlash®£º20 G @ DIN£¬°ëÕýÏÒ²¨£¬11ºÁÃ룬 50 G @ ±Ú¹Òʽ°²×°/Ãæ°å°²×°£¬°ëÕýÏÒ²¨£¬11 ºÁÃë Õñ¶¯±£»¤ IEC 68 2-6 CompactFlash®£º2 Grms @ ÕýÏÒ²¨£¬5 ~ 500Hz, 1 Oct./·ÖÖÓ£¬1Сʱ/Öá¡£ Ó²ÅÌ£º 1 Grms @ ÕýÏÒ²¨£¬12 ~ 300 Hz, 1 Oct./·ÖÖÓ£¬1Сʱ/Öá¡£ ¶©»õÐÅÏ¢ UNO-2052E-IDA0E GX2 400 M, 256 MB RAM UNO-2052E
UNO-2059E ÑлªUNO-2059E AMD GX 2-400 MHz´øPC¿¨,LAN,2xUSB£¬2xRS-232/485£¬2xRS-232/422/485µÄÎÞ·çÉÈǶÈëʽ¿ØÖÆÆ÷ ¸ÅÊö Ñлª UNO-2059E ÊÇÒ»¸ö´øÓÐ USB ¼° PC ¿¨½Ó¿ÚµÄ 586 ¼¶¿ØÖÆƽ̨£¬Äܹ»Âú×ãÄú¸÷ÖÖ I/O É豸µÄÀ©Õ¹ÐèÇó¡£ ´ËÍ⣬Ëü»¹´øÓÐ 2 ¸ö RS-232/485 ¶Ë¿ÚºÍ 2 ¸ö´ø RS-485 ×Ô¶¯Êý¾ÝÁ÷¿ØÖƵĸôÀë RS-232/422/485 ͨѶ¶Ë¿Ú¡£ UNO-2059E ΪҪÇóÇ¿´óÔËËãºÍͨѶ¹¦ÄܵÄÓ¦ÓÃÌṩÁËÒ»Ì×ÀíÏëµÄ½ô´ÕÐͽâ¾ö·½°¸¡£ UNO-2059E ÄÚÖà Windows CE OS£¬Ìṩ¶¨ÖƵÄÓ³ÏñÎļþ£¬´øÓÐÓÅ»¯ºóµÄ°åÔØÉ豸Çý¶¯³ÌÐò¡£ Microsoft Windows® CE ÊÇÒ»Ì×½ô´Õ¡¢¸ßЧµÄʵʱ²Ù×÷ϵͳ£¬ËüÊÇΪÎÞÓ²ÅÌÏÞÖƵÄǶÈëʽϵͳ¶øÉè¼ÆµÄ¡£Èç¹ûÒªÀ©Õ¹´æ´¢ÈÝÁ¿£¬UNO-2059E »¹¿ÉÒÔʹÓÃÑлª UNO Ó²ÅÌÀ©Õ¹Ì×¼þÀ©Õ¹Ò»¿éÍⲿ 2.5¡± Ó²ÅÌ¡£ À©Õ¹µÄÓ²ÅÌ¿ÉÓÃÀ´½øÐдóÅúÁ¿Êý¾Ý±¸·ÝºÍ°²×°Í¨Óà OS Èç Microsoft Windows ºÍ Linux OS¡£ ¼´Ê¹ÆäÄÚ²¿Ê¹ÓûúеʽӲÅÌ£¬ËüÒÀÈ»¾ßÓÐÁ¼ºÃµÄ¿¹ÕñÐÔÄÜ (1G w/ HDD)¡£UNO-2059E ÊÇÒ»¿îÄܹ»Ëõ¶ÌÄúµÄÓ¦Óÿª·¢ÖÜÆÚ£¬²¢Ìṩ·á¸»µÄÍøÂç½Ó¿ÚÒÔÂú×ãÄú²»Í¬ÏîÄ¿ÐèÇóµÄÀíÏëµçÄÔƽ̨¡£ ÌØÐÔ °åÉϼ¯³É AMD GX2-400 MHz CPU 2 ¸ö RS-232/485 ºÍ 2 ¸ö RS-232/422/485 ¶Ë¿Ú£¬´ø×Ô¶¯Êý¾ÝÁ÷¿ØÖÆ¡£ 1 ¸ö 10/100Base-T RJ-45 ¶Ë¿Ú 2 ¸ö USB ºÍ 1 ¸ö Type I/II PC ¿¨¡£ 1 ¸ö¿É±à³ÌÕï¶Ï LED ָʾµÆºÍ·äÃùÆ÷¡£ Microsoft® Windows® CE .NET ½â¾ö·½°¸¡£ Ö§³Ö Windows® 2000/XP ºÍ Linux Çý¶¯³ÌÐò Ìṩ Windows® CE .NET 4.2 Binary BSP ¹æ¸ñ Ò»°ã¹æ¸ñ ³ß´ç 188.8 x 106.5 x 35.5 mm (7.5¡± ¡Á 4.2" x 1.4¡±) Íâ¿Ç Aluminum °²×° Wall, DIN 35 rail ¹¦ºÄ 15 W (µäÐÍ) µçÔ´ÊäÈë ×îС 24 W (9~36 VDC) (ÀýÈç +24 V @ 1 A) µçÔ´ 9 ~ 36 VDC ÖØÁ¿ 0.8 kg OS Ö§³Ö Windows® 2000, Windows® CE .NET 5.0, Linux ϵͳӲ¼þ CPU AMD GX 533-400 MHz ÄÚ´æ 256 MB DDRRAM on board ָʾµÆ µçÔ´ LED¡¢IDE LED£¬1 ¸ö¿É±à³ÌÕï¶Ï LED ºÍ1 ¸ö·äÃùÆ÷ LED ¼üÅÌ/Êó±ê 1 x PS/2 ÄÚ´æ °åÉϼ¯³É 128/256 MB DDR DRAM ´æ´¢ ¹Ì̬µç×ÓÅÌ£º 1 ¸öÄÚ²¿ Type I/II CompactFlash®²å²Û Ó²ÅÌ£º ÓÃÓÚÒ»¸ö 2.5" Ó²Å̵ÄÀ©Õ¹×é¼þVGA DB15 ½Ó¿Ú ͨѶ ´®¿Ú 2 ¡Á ±ê×¼ RS-232£¬2 ¡Á RS-232/RS-422/485 - ×Ô¶¯ RS-485 Êý¾ÝÁ÷¿ØÖÆ - RS-422/485 ÀËÓ¿±£»¤×î¸ß´ï 2,000 VDC ´®¿ÚËÙ¶È RS-232£º 50 ~ 230.4 kbps£»RS-422/485£º 50 bps ~ 921.6 kbps (×î´ó) USB ¶Ë¿Ú 2 ¸ö USB ¶Ë¿Ú£¬·ûºÏ OpenHCI Rev. 1.1 ¹æ¸ñ LAN 1 ¸ö 10/100Base-T RJ-45 ¶Ë¿Ú PC ¿¨ 1 ¸ö PC ¿¨²å²Û Ö§³Ö CardBus (Card-32) ¿¨ºÍ 16 λ (PCMCIA 2.1/JEIDA4.2) ¿¨ Ö§³Ö +5 V¡¢+3.3 V ºÍ +12 V @ 120 mA ¹¤×÷µçÔ´ ¿´ÃŹ·¶¨Ê±Æ÷ ¿É±à³Ì »·¾³ ʪ¶È 95 % @ 40¡ã C£¨ÎÞÄý½á£© Èë¿Ú±£»¤ IP40 ¹¤×÷ÎÂ¶È -10 ~ 55¡ã C (14 ~ 131¡ã F) ³å»÷±£»¤ IEC 68 2-27 CompactFlash®£º 20 G @ DIN£¬°ëÕýÏÒ²¨£¬11ºÁÃ룬 50 G @ ±Ú¹Òʽ°²×°/Ãæ°å°²×°£¬°ëÕýÏÒ²¨£¬11 ºÁÃë Õñ¶¯±£»¤ IEC 68 2-6 CompactFlash®£º 2 Grms @ ÕýÏÒ²¨£¬5 ~ 500Hz, 1 Oct./·ÖÖÓ£¬1Сʱ/Öá¡£ Ó²ÅÌ£º 1 Grms @ ÕýÏÒ²¨£¬12 ~ 300 Hz, 1 Oct./·ÖÖÓ£¬1Сʱ/Öá¡£ ¶©»õÐÅÏ¢ UNO-2059E-IDA0E GX2 400 M, 256 MB RAM UNO-2059E
UNO-2171 ÑлªUNO-2171Intel® Pentium®M´ø2xLAN,4xCOM,PC/104+ÎÞ·çÉÈǶÈëʽ¹¤Òµ¼¶¿ØÖÆÆ÷£¬ ¸ÅÊö UNO-2171ÊÇÒ»¿îÖ§³ÖPC/104+À©Õ¹¡¢´®ÐÐͨѶ¶Ë¿ÚºÍÆäËûÍøÂç½Ó¿ÚµÄǶÈëʽ¹¤Òµ¼¶¿ØÖÆÆ÷¡£UNO-2171 Ö§³ÖWindows XP Embedded OSºÍWindowsCE 5.0£¬Äܹ»Ìṩ¶¨ÖƵÄÓ³ÏñÎļþ£¬´øÓÐÓÅ»¯¹ýµÄ°åÔØÉ豸Çý¶¯³ÌÐò¡£Ç¶ÈëʽWindows XP Äܹ»ÒÔ×é¼þ·½Ê½ÌṩWindows²Ù×÷ϵͳµÄ¹¦ÄÜ¡£Äú¿ÉÒÔ·½±ãµØ½«×Ô¼ºµÄÓ¦ÓÃÈí¼þÎÞ·ìµØÕûºÏµ½Windows XP EmbeddedÖУ¬Í¨¹ýʹÓôøÓзḻÍøÂç½Ó¿ÚµÄÓ¦ÓÃÈí¼þ¼´ÓÃƽ̨À´¼Ó¿ìÄúµÄϵͳ¿ª·¢£¬ÒÔÂú×㲻ͬµÄÐèÇó¡£ ÌØÐÔ °åÉϼ¯³ÉPentium® M1.4GHz»òCeleron® M 1.0GHz´¦ÀíÆ÷ Ìṩ512 KBµç³Ø±¸·ÝSRAM 2¸öRS-232ºÍ2¸öRS-232/422/485¶Ë¿Ú£¬´ø×Ô¶¯Êý¾ÝÁ÷¿ØÖÆ 2¸ö10/100Base-T RJ-45¶Ë¿Ú ÒôƵ£¬´øÂó¿Ë·çÊäÈë¡¢Ïß·ÊäÈëºÍÏß·Êä³ö 2¸öUSB¶Ë¿ÚºÍ1¸öType I/II PC¿¨ PC/104+À©Õ¹²å²Û Windows® CE 5.0£¬Windows XP Embedded SP2ºÍLinux¼´Óýâ¾ö·½°¸ ¹æ¸ñ Ò»°ã¹æ¸ñ ÈÏÖ¤ CE, FCC class A, UL ³ß´ç(W¡ÁD¡ÁH) 255¡Á152¡Á59 mm (10"¡Á6.0"¡Á2.3") Íâ¿Ç ÂÁÖÊÍâ¿Ç °²×°£¨¿ÉÑ¡£© ±Ú¹Òʽ°²×° ¹¦ºÄ 24 W£¨µäÐÍ) µçÔ´ÊäÈë 10 ~ 53 VDC (Èç+24 V @ 2 A) (×îС48 W), ATX ¾»ÖØ 2.4 kg£¨µäÐÍ£© OSÖ§³Ö Windows XP embedded, Windows 2000/XP, WinCE 5.0, Linux ϵͳӲ¼þ CPU Pentium M 1.4 GHz, Celeron M 1.0 GHz ÄÚ´æ 512 MB/1 GB DDR SDRAM µç³Ø±¸·ÝRAM 512 KB ָʾµÆ ÌṩµçÔ´¡¢IDE¡¢µç³Ø±¸·Ý±¨¾¯µÄLEDָʾµÆ¡£ ¼üÅÌ/Êó±ê 1¡ÁPS/2 PC¿¨ 1¡ÁPC¿¨²å²Û£¬Ö§³ÖCardBus (Card-32)¿¨£¬ 16λ(PCMCIA 2.1/JEIDA4.2)¿¨Ö§³Ö+5 V¡¢+3.3 V PC/104+ PC/104+²å²Û£¬Ö§³Ö+5 VµçÔ´ ´æ´¢ ¹Ì̬µç×ÓÅÌ 2¡ÁÄÚÖÃType I/II CompactFlash® ²å²Û Ó²ÅÌ Ò»¸ö±ê×¼2.5"Ó²ÅÌ VGA DB15 VGA½Ó¿Ú£¬1600 x 1200 @ 85 Hz ÒôƵ Âó¿Ë·çÊäÈ룬Ïß·ÊäÈ룬Ïß·Êä³ö ¿´ÃŹ·¶¨Ê±Æ÷ ¿É±à³Ì ͨѶ ´®¿Ú 2¡ÁRS-232, 2¡ÁRS-232/422/485£¬´øDB9½Ó¿Ú£¬×Ô¶¯RS-485Êý¾ÝÁ÷¿ØÖÆ ´®¿ÚËÙ¶È RS-232: 50 bps ~ 115.2 kbps RS-422/485: 50 bps ~ 921.6 kbps(×î´ó) LAN 2¡Á10/100Base-T RJ-45¶Ë¿Ú USB¶Ë¿Ú 2¡ÁUSB£¬·ûºÏUSB UHCI, Rev. 2.0±ê×¼ »·¾³ ʪ¶È 95% @ 40¡ãC (ÎÞÄý½á) ¹¤×÷ÎÂ¶È -20 ~ 65¡ãC (-4 ~ 149¡ãF) @ 5 ~ 85% RH ³å»÷±£»¤ IEC 68 2-27 CompactFlash£º50 G @ ±Ú¹Òʽ°²×°£¬°ëÕýÏÒ²¨£¬11ºÁÃë Ó²ÅÌ£º20 G @±Ú¹Òʽ°²×°£¬°ëÕýÏÒ²¨£¬11ºÁÃë Õñ¶¯±£»¤ IEC 68 2-64 (Ëæ»ú1 Oct./·ÖÖÓ, 1Сʱ/Öá.) CompactFlash£º2 Grms @ 5 ~ 500 Hz Ó²ÅÌ£º1 Grms @ 5 ~ 500 Hz ¶©»õÐÅÏ¢ UNO-2171-C11E C-M 1.0 G, 512 MB RAM UNO-2171 UNO-2171-P11E P-M 1.4 G, 512 MB RAM UNO-2171 UNO-2171-P12E P-M 1.4 G, 1 GB RAM UNO-2171 Åä¼þ UNO-PCM22-AE 2¡ÁPC/104À©Õ¹Ì×¼þ(½Óµ¥Éú²ú) UNO-FPM21-AE UNOºÍFPM¼¯³ÉÌ×¼þ(½Óµ¥Éú²ú)
UNO-2173A ÑлªUNO-2173A Intel® Atom™ 1xLAN,2xCOM£¬Mini-PCIeÎÞ·çÉÈǶÈëʽ¹¤Òµ¿ØÖÆÆ÷ ¸ÅÊö UNO-2173AÊÇÒ»¿îÎÞ·çÉÈǶÈëʽ¹¤ÒµµçÄÔ£¬Ö§³ÖMini-PCIeÀ©Õ¹£¬´®ÐÐͨѶ¶Ë¿ÚºÍÆäËûһЩÍøÂç½Ó¿Ú¡£UNO-2173AÖ§³ÖWindows XP Embedded²Ù×÷ϵͳºÍWindows CE 5.0 & 6.0£¬²¢ÇÒÒѾͨ¹ýEnergy StarÈÏÖ¤£¬Ö§³ÖIP-40µÈ¼¶·À³¾±£»¤ºÍ¿íβÙ×÷£¨-20 ~ 70¡ã C£©£¬³ä·ÖÂú×ãÁ˹¤Òµ×Ô¶¯»¯Ó¦Óõĵ͹¦ºÄÇÒ¾¼ÃÓÐЧµÄÐèÇó£¬ÍêÃÀ³ÊÏÖ³ö¸ßÐÔÄܵ͹¦ºÄµÄ׿ԽƷÖÊ¡£ ÌØÐÔ °åÉϼ¯³ÉIntel® Atom™ 1.6 GHz´¦ÀíÆ÷ 1¸ö10/100/1000Base-T RJ-45¶Ë¿Ú 2¸öUSB 2.0¶Ë¿Ú Ö§³ÖWindows® CE 5.0 & 6.0£¬Windows XP EmbeddedºÍLinux¼´Óýâ¾ö·½°¸ °åÉϼ¯³Éϵͳ״̬LEDָʾµÆ Ç°³öÏßCF¿¨²å²Û Ö§³ÖÍøÂçÆô¶¯¹¦ÄÜ 1¸öMini-PCIe²å²ÛÖ§³ÖÎÞÏßÍø¿¨ ÎÞÄÚ²¿²¼Ïߣ¬ÎÞ·çÉÈÉè¼Æ »úÏäºÍµçÔ´Ö®¼ä¸ôÀë½ÓµØ Ö§³Ö¿í²Ù×÷ζȣ¨×î¸ßµ½70¡ã C£© IP40·À»¤µÈ¼¶
UNO-2173AF ÑлªUNO-2173AF Intel® Atom™ 1xLAN£¬2Xcom,Mini-PCIeÎÞ·çÉÈǶÈëʽ¹¤Òµ¿ØÖÆÆ÷ ¸ÅÊö UNO-2173AFÊÇÒ»¿îÎÞ·çÉÈǶÈëʽ¹¤ÒµµçÄÔ£¬Ö§³ÖMini-PCIeÀ©Õ¹£¬´®ÐÐͨѶ¶Ë¿ÚºÍÆäËûһЩÍøÂç½Ó¿Ú¡£UNO-2173AFÖ§³ÖWindows XP Embedded²Ù×÷ϵͳºÍWindows CE 5.0 & 6.0£¬²¢ÇÒÒѾͨ¹ýEnergy StarÈÏÖ¤£¬Ö§³ÖIP-40µÈ¼¶·À³¾±£»¤ºÍ¿íβÙ×÷£¨-20 ~ 70¡ã C£©£¬³ä·ÖÂú×ãÁ˹¤Òµ×Ô¶¯»¯Ó¦Óõĵ͹¦ºÄÇÒ¾¼ÃÓÐЧµÄÐèÇó£¬ÍêÃÀ³ÊÏÖ³ö¸ßÐÔÄܵ͹¦ºÄµÄ׿ԽƷÖÊ¡£ ÌØÐÔ °åÉϼ¯³ÉIntel® Atom™ 1.6 GHz´¦ÀíÆ÷ 1¸ö10/100/1000Base-T RJ-45¶Ë¿Ú 2¸öUSB 2.0¶Ë¿Ú Ö§³ÖWindows® CE 5.0 & 6.0£¬Windows XP EmbeddedºÍLinux¼´Óýâ¾ö·½°¸ °åÉϼ¯³Éϵͳ״̬LEDָʾµÆ Ç°³öÏßCF¿¨²å²Û Ö§³ÖÍøÂçÆô¶¯¹¦ÄÜ 1¸öMini-PCIe²å²ÛÖ§³ÖÎÞÏßÍø¿¨ ÎÞÄÚ²¿²¼Ïߣ¬ÎÞ·çÉÈÉè¼Æ »úÏäºÍµçÔ´Ö®¼ä¸ôÀë½ÓµØ Ö§³Ö¿í²Ù×÷ζȣ¨×î¸ßµ½70¡ã C£© IP40·À»¤µÈ¼¶
UNO-2174A/UNO-2178A ÑлªUNO-2174A/UNO-2178A Intel® Atom™ N450 6xUSB, 4xCOM, 2xMini PCIeÎÞ·çÉÈǶÈëʽ¹¤Òµ¿ØÖÆÆ÷ ¸ÅÊö UNO-2174AºÍUNO-2178AÊÇÁ½¿îÄÚº¬Ó¢ÌضûÁ趯´¦ÀíÆ÷µÄÎÞ·çÉÈǶÈëʽ¹¤ÒµµçÄÔ¡£ÕâÁ½¿î²úÆ··Ö±ð²ÉÓõ͹¦ºÄÁ趯N450ºÍD510 1.67GHz´¦ÀíÆ÷£¬°åÔØ2GB DDR2 RAM£¬Ç§Õ×ÒÔÌ«Íø¶Ë¿Ú£¬·á¸»µÄI/O£¬2¸öMini PCIe²Û£¬¿ÉÁé»îÀ©Õ¹Wi-Fi / 3GÄ£¿é£¬¼æÈÝWindows 7¡£Á½¿î²úÆ·¾ù¾ßÓÐÄÜÁ¿Ö®ÐÇÈÏÖ¤£¬IP40·À³¾µÈ¼¶ÈÏÖ¤£¬-10 ~ 70¡ã C¿íÎÂÔËÐеÈÌØÐÔ¡£ÁíÖ§³ÖPC/104+ ºÍPCI-104×Ó°åÀ©³ä²å¼þ¡¢¸½¼ÓI/OÄ£¿éºÍ×ÜÏß¿¨µÈ¡£¹¦ºÄ¸üµÍ¡¢ÐÔÄܸü¼Ó׿Խ¡£ UNO-2174AºÍUNO-2178AÊÇÑÏ¿Á¹¤Òµ»·¾³µÄÀíÏë¶ø¾¼ÃµÄÑ¡Ôñ£¬Ó¦ÓÃÁìÓò°üÀ¨£º¹¤³§×Ô¶¯»¯¡¢É豸×Ô¶¯»¯¡¢Î£ÏÕÔ´¼à¿Ø¡¢Ì«ÑôÄܹâ·ü¡¢»·¾³¼à²â¡¢Â¥Óî½ÚÄܵȡ£ ÌØÐÔ °åÔØIntel Atom N450 ´¦ÀíÆ÷ 2¸ö10/100/1000 Base-T RJ-45¶Ë¿Ú£¬6¸öUSB 2.0¶Ë¿Ú Ö§³ÖWindows® CE 6.0, WES 2009, WES 7 ¼°Linux °åÔØϵͳ״̬LEDָʾµÆ Ç°ÖÃCF¿¨²Û Ö§³ÖLAN ¹¦ÄÜÆô¶¯ 2¸öMini PCIe ¿¨²Û£¬1¸öSIM¿¨²Û ÎÞ·çÉÈÓëÎÞÈíÏßÁ¬½ÓÉè¼Æ »úÏäÓëµçÔ´½ÓµØÖ®¼äµÄ¸ôÀë±£»¤ Ö§³Ö¿íÎÂÔËÐУº - 10 ~ 70¡ã C IP40 ·À»¤µÈ¼¶ÈÏÖ¤ Ö§³ÖWindows 7 32 & 64λ Ö§³Ö²å¿¨(1 x PCI-104 and 1 x PC/104+)£¬¿ÉÌí¼Ó¶îÍâµÄÀ©Õ¹×Ó°å Ö§³ÖÈÎÒⲨÌØÂÊ
UNO-2182 ÑлªUNO-2182´ø2xLAN£¬4xCOM£¬DVIÎÞ·çÉÈǶÈëʽ¹¤Òµ¼¶¿ØÖÆÆ÷ ¸ÅÊö UNO-2182ÊÇÒ»¿îÖ§³ÖPC/104À©Õ¹¡¢´®ÐÐͨѶ¶Ë¿ÚºÍÆäËûÍøÂç½Ó¿ÚµÄ¸ßÐÔÄÜCore Duo¼¶¿ØÖÆÆ÷¡£UNO-2182 Ö§³ÖWindows XP Embedded OS£¬Äܹ»Ìṩ¶¨ÖƵÄÓ³ÏñÎļþ£¬´øÓÐÓÅ»¯¹ýµÄ°åÔØÉ豸Çý¶¯³ÌÐò¡£Ç¶ÈëʽWindows XP Äܹ»ÒÔ×é¼þ·½Ê½ÌṩWindows²Ù×÷ϵͳµÄ¹¦ÄÜ¡£Äú¿ÉÒÔ·½±ãµØ½«×Ô¼ºµÄÓ¦ÓÃÈí¼þÎÞ·ìµØÕûºÏµ½Windows XP EmbeddedÖУ¬Í¨¹ýʹÓôøÓзḻÍøÂç½Ó¿ÚµÄÓ¦ÓÃÈí¼þ¼´ÓÃƽ̨À´¼Ó¿ìÄúµÄϵͳ¿ª·¢£¬ÒÔÂú×㲻ͬµÄÐèÇó¡£ ÌØÐÔ °åÉϼ¯³ÉCore.Duo 1.66 GHz´¦ÀíÆ÷ Ìṩ512 KBµç³Ø±¸·ÝSRAM 2¸öRS-232ºÍ2¸öRS-232/422/485¶Ë¿Ú£¬´ø×Ô¶¯Êý¾ÝÁ÷¿ØÖÆ 2¸ö10/100/1000Base-T ÒÔÌ«Íø¿Ú DVI-IÖ§³ÖË«ÖØÏÔʾ ÒôƵ£¬´øÂó¿Ë·çÊäÈë¡¢Ïß·ÊäÈëºÍÏß·Êä³ö 2¸öUSB¶Ë¿ÚºÍ1¸öType I/II PC¿¨ PC/104À©Õ¹²å²Û Windows XP Embedded SP2¼´Óýâ¾ö·½°¸ Ö§³ÖSATA-1Ó²Å̺ÍÍâÖÃeSATAÉ豸 Ò»°ã¹æ¸ñ ÈÏÖ¤ CE, FCC class A, UL ³ß´ç(W¡ÁD¡ÁH) 255¡Á152¡Á69 mm (10"¡Á6.0"¡Á2.7") Íâ¿Ç ÂÁÖÊÍâ¿Ç °²×°£¨¿ÉÑ¡£© ±Ú¹Òʽ°²×° ¹¦ºÄ 35W£¨µäÐÍ£© µçÔ´ÊäÈë ×îС48 W (9 ~ 36 VDC) (Èç+24 V @ 2 A) , ATX ¾»ÖØ 2.4 kg OSÖ§³Ö Windows XP embedded, Windows 2000/XP ϵͳӲ¼þ CPU Core Duo 1.66 GHz ÄÚ´æ 512 MB/1 GB DDR2 SDRAM ָʾµÆ ÌṩµçÔ´¡¢IDE¡¢µç³Ø±¸·Ý±¨¾¯µÄLEDָʾµÆ¡£µç³Ø±¸·ÝRAM 512 KB ¼üÅÌ/Êó±ê 1¡ÁPS/2 PC¿¨ 1¡ÁPC¿¨²å²Û£¬Ö§³ÖCardBus (Card-32)¿¨£¬ 16λ(PCMCIA 2.1/JEIDA4.2)¿¨Ö§³Ö+5 V¡¢+3.3V PC/104 PC/104²å²Û ´æ´¢ ¹Ì̬µç×ÓÅÌ1¡ÁÍâÖÃType I/II CompactFlash® ²å²Û Ó²ÅÌ 1¡Á±ê×¼2.5"Ó²ÅÌ(PATA»òSATA) ÏÔʾ DVI-IÖ§³ÖDVIºÍVGAË«ÖØÏÔʾ ÒôƵ Âó¿Ë·çÊäÈ룬Ïß·ÊäÈ룬Ïß·Êä³ö SATA 1¸öÄÚÖã¬1¸öÍâÖÃeSATA ¿´ÃŹ·¶¨Ê±Æ÷ ¿É±à³Ì ͨѶ ´®¿Ú 2¡ÁRS-232, 2¡ÁRS-232/422/485£¬´øDB9½Ó¿Ú£¬×Ô¶¯RS-485Êý¾ÝÁ÷¿ØÖÆ ´®¿ÚËÙ¶È RS-232: 50 bps ~ 115.2 kbps RS-422/485:50 bps ~ 921.6 kbps (×î´ó) LAN 2¡Á10/100/1000Base-T RJ-45¶Ë¿Ú USB¶Ë¿Ú2¡ÁUSB·ûºÏUSB UHCI, Rev.2.0±ê×¼ »·¾³ ʪ¶È 95% @ 40¡ãC (ÎÞÄý½á) ¹¤×÷ÎÂ¶È -20 ~ 60¡ãC (-4 ~ 140¡ãF) @ 5 ~ 85% RH ³å»÷±£»¤ IEC 68 2-27 CompactFlash£º50 G @ ±Ú¹Òʽ°²×°£¬°ëÕýÏÒ²¨£¬11ºÁÃë Ó²ÅÌ£º20 G @±Ú¹Òʽ°²×°£¬°ëÕýÏÒ²¨£¬11ºÁÃë Õñ¶¯±£»¤ IEC 68 2-64 (Ëæ»ú1 Oct./·ÖÖÓ, 1Сʱ/Öá.) CompactFlash£º2 Grms @ 5 ~ 500 Hz Ó²ÅÌ£º1 Grms @ 5 ~ 500 Hz ¶©»õÐÅÏ¢ UNO-2182-D11E C-D 1.66 G, 512 MB RAM UNO-2182 UNO-2182-D12E C-D 1.66 G, 1 GB RAM UNO-2182 Åä¼þ UNO-PCM22-AE 2¡ÁPC/104À©Õ¹Ì×¼þ(½Óµ¥Éú²ú) UNO-FPM21-AE UNOÓëFPM¼¯³ÉÌ×¼þ(½Óµ¥Éú²ú)
UNO-2679 ÑлªUNO-2679 Celeron® M 1 GHzË«Ö±Á÷µçÔ´ÊäÈ룬´ø4 x LAN£¬4 x USB£¬2xRS-232£¬4x¹â¸ôÀëRS232/422/485£¬8xDI£¬8 x DO£¬1 x PC/104À©Õ¹ÎÞ·çÉÈǶÈëʽ¿ØÖÆÆ÷ ¸ÅÊö UNO-2679ÊÇÒ»¿î¸ßÐÔÄÜÎÞ·çÉȵÄͨÓÃÍøÂç¿ØÖÆÆ÷£¬Ö§³Ö´®ÐÐͨÐŶ˿ڡ¢ÒÔÌ«ÍøÒÔ¼°Êý×ÖÁ¿ÊäÈëÊä³ö¹¦ÄÜ¡£UNO-2679´øÓÐ4¸öLAN¡¢2¸ö±ê×¼RS-232C¡¢4¸öRS-232C/422/485£¨¿ÉÉ趨¡¢¸ôÀ룩¡¢8¸ö¸ôÀëÊý×ÖÁ¿ÊäÈëºÍ8¸ö¸ôÀëÊý×ÖÁ¿Êä³öµÈ½Ó¿Ú£¬Ö§³ÖWindows XP Embedded¡¢Windows CE.NETºÍLinux£¬Äܹ»Ìṩ¿É¶¨ÖÆÓ³ÏñÎļþ£¬´øÓÐÓÅ»¯°åÔØÉ豸Çý¶¯³ÌÐò£¬ÒÔÂú×㲻ͬµÄÓ¦ÓÃÐèÇó¡£ ÌØÐÔ °åÉϼ¯³ÉIntel® Celeron® M 1 GHz´¦ÀíÆ÷ Ë«Ö±Á÷µçÔ´ÊäÈë 2¸öRS-232ºÍ4¸ö¸ôÀëRS-232/422/485¶Ë¿Ú£¬ RS-485´ø×Ô¶¯Êý¾ÝÁ÷¿ØÖÆ 8·¸ôÀëDI£¬8·¸ôÀëDO 4¸ö10/100 Base-TÒÔÌ«Íø¶Ë¿Ú 4¸öUSBºÍ1¸öType¢ñ/¢ò CF¿¨²å²Û Windows CE.NET¡¢Windows XP EmbeddedºÍLinux½â¾ö·½°¸ ¹æ¸ñ Ò»°ã¹æ¸ñ ³ß´ç 440 ¡Á 220 ¡Á 44 mm Íâ¿Ç SECC½ðÊôÍâ¿Ç °²×° 1U 19¡±»ú¼Ü°²×° ¹¦ºÄ 20 W£¨µäÐÍ£©¾»ÖØ 3.6 kg µçÔ´ÊäÈ뷶Χ Ë«Ö±Á÷µçÔ´£¬18 ~ 30 VDC OSÖ§³Ö Windows CE¡¢Windows XP Embedded¡¢Windows XP¡¢Linux ϵͳÉè¼Æ ÎÞ·çÉÈϵͳÉè¼Æ ϵͳӲ¼þ CPU Celeron®M1GHzÄÚ´æDDR SODIMM 1 GB ÏÔʾ DB-15 VGAÁ¬½Ó,1600¡Á1200 @ 85 Hz ¼üÅÌ&Êó±ê PS/2½Ó¿Ú ´æ´¢1xÄÚÖÃType¢ñ/¢òCompact Flash¿¨²Û1 x ÄÚÖÃIDE½Ó¿Ú 8·¸ôÀëÊý×ÖÊäÈë ͨµÀ 8 ¸ôÀë±£»¤2000 VDC¹ýѹ±£»¤ 50 VDC ÊäÈ뷶Χ 0 ~ 30 VDC ÊäÈëµçѹ Âß¼0£º0 ~ 3 VDC£»Âß¼1£º5 ~ 30 VDC ÊäÈëµçÁ÷ 10 VDC @ 2.5 mA¡¢12 VDC @ 3.1 mA¡¢24 VDC @ 6.5 mA 8·¸ôÀëÊý×ÖÊä³ö ͨµÀ 8 ¸ôÀë±£»¤ 2000 VDC Êä³ö·¶Î§ 5 ~ 40 VDC ͨѶ ´®¿Ú 2 ¡Á ±ê×¼RS-232ºÍ4 ¡Á ¸ôÀëRS-232/422/485¶Ë¿Ú ´®¿ÚËÙ¶È ×î´ó115.2 kbps LAN 4 x 10/100 Base-TÒÔÌ«Íø¶Ë¿Ú USB½Ó¿Ú 4·£¬¼æÈÝUSB2.0 ָʾµÆ µçÔ´¡¢IDE¡¢Í¨Ñ¶Tx/Rx¼ì²â¡¢LAN¡¢DI/DOµÈ LED¿´ÃŹ·¶¨Ê±Æ÷ 1·£¨¿É±à³Ì£© »·¾³ ʪ¶È 95% @ 40¡ã C£¨·ÇÄý½á£©¹¤×÷ÎÂ¶È -10 ~ 50¡ã C @ 5 ~ 85%RH ¶©»õÐÅÏ¢ UNO-2679-C12E C-M 1.0 G, 1 G RAM×Ô¶¯»¯µçÄÔ Åä¼þ 1701440151 IDEÓ²ÅÌÏß 1960014827N000 2.5¡±Ó²ÅÌ¼Ü PCLS-DIAGAW10 DiagAnywhereÔ¶³Ìά»¤Èí¼þ
UNO-2679COM ÑлªUNO-2679COM Celeron® M 1GHz 2U¼Ü¹¹£¬Ë«Ö±Á÷µçÔ´ÊäÈ룬´ø4xLAN£¬18xCOM£¬16xDIOÎÞ·çÉÈǶÈëʽ¿ØÖÆÆ÷ ¸ÅÊö UNO-2679COMÊÇÒ»¿î¸ßÐÔÄÜÎÞ·çÉÈͨÓÃÍøÂç¿ØÖÆÆ÷£¬Ö§³Ö´®ÐÐͨÐŶ˿ڡ¢ÒÔÌ«Íø¼°Êý×ÖÁ¿ÊäÈëÊä³ö¹¦ÄÜ¡£UNO-2679COM´øÓÐ4¸öLAN¡¢2¸ö±ê×¼RS-232C¡¢4¸öRS-232C/422/485£¨¿ÉÉ趨¡¢¸ôÀ룩¡¢12¸öRS-422/485£¨¿ÉÉ趨¡¢¸ôÀ룩¡¢8¸ö¸ôÀëÊý×ÖÁ¿ÊäÈëºÍ8¸ö¸ôÀëÊý×ÖÁ¿Êä³öµÈ½Ó¿Ú£¬Ö§³ÖWindowsXP Embedded¡¢Windows CE.NETºÍLinux£¬Äܹ»Ìṩ¿É¶¨ÖÆÓ³ÏñÎļþ£¬´øÓÐÓÅ»¯°åÔØÉ豸Çý¶¯³ÌÐò£¬ÒÔÂú×㲻ͬµÄÓ¦ÓÃÐèÇó¡£ ÌØÐÔ °åÉϼ¯³ÉIntel® Celeron® M 1 GHz´¦ÀíÆ÷ Ë«Ö±Á÷µçÔ´ÊäÈë 2¸ö±ê×¼RS-232¡¢4¸ö¸ôÀëRS-232/422/485¶Ë¿ÚºÍ12¸ö¸ôÀëRS422/485¶Ë¿Ú£¬RS-485´ø×Ô¶¯Êý¾ÝÁ÷¿ØÖÆ 8·¸ôÀëDI£¬8·¸ôÀëDO 4¸ö10/100 Base-TÒÔÌ«Íø¶Ë¿Ú 4¸öUSBºÍ1¸öType¢ñ/¢ò CF¿¨²å²Û Windows® CE¡¢Windows® XP EmbeddedºÍLinux½â¾ö·½°¸ ¹æ¸ñ Ò»°ã¹æ¸ñ ³ß´ç 440 ¡Á 220 ¡Á 88 mm Íâ¿Ç SECC, ½ðÊôÍâ¿Ç °²×° 2U 19¡±»ú¼Ü°²×° ¹¦ºÄ 30 W£¨µäÐÍ£© ¾»ÖØ 4.2 kg µçÔ´ÊäÈ뷶Χ Ë«Ö±Á÷µçÔ´£¬18 ~ 30 VDC OSÖ§³Ö Windows CE.NET¡¢Windows XPEmbedded¡¢Windows XP¡¢Linux ϵͳÉè¼Æ ÎÞ·çÉÈϵͳÉè¼Æ ϵͳӲ¼þ CPU Celeron®M 1GHzÄÚ´æDDR SODIMM 512M ÏÔʾDB-15VGAÁ¬½Ó£¬1600¡Á1200 @ 85 Hz ¼üÅÌ&Êó±ê PS/2½Ó¿Ú ´æ´¢ 1xÄÚÖÃType¢ñ/¢òCompact Flash¿¨²Û 1 x ÄÚÖÃIDE½Ó¿Ú 8·¸ôÀëÊý×ÖÊäÈë ͨµÀ 8 ¸ôÀë±£»¤ 2000 VDC ¹ýѹ±£»¤ 50 VDC ÊäÈ뷶Χ 0 ~ 30 VDC ÊäÈëµçѹ Âß¼0£º0 ~ 3 VDC£»Âß¼1£º5 ~ 30 VDC ÊäÈëµçÁ÷ 10 VDC @ 2.5 mA¡¢12 VDC @ 3.1 mA¡¢24 VDC @ 6.5 mA 8·¸ôÀëÊý×ÖÊä³ö ͨµÀ 8 ¸ôÀë±£»¤ 2000 VDC Êä³ö·¶Î§ 5 ~ 40 VDC ͨѶ ´®¿Ú 2 ¡Á ±ê×¼RS-232¡¢4 ¡Á ¸ôÀëRS-232/422/485¶Ë¿ÚºÍ 12 x ¸ôÀëRS-232/422/485¶Ë¿Ú ´®¿ÚËÙ¶È ×î´ó115.2 kbps LAN 4 ¡Á 10/100 Base-T RJ-45¶Ë¿Ú USB½Ó¿Ú 4·£¬¼æÈÝUSB2.0 ָʾµÆ µçÔ´¡¢IDE¡¢Í¨Ñ¶Tx/Rx¼ì²â¡¢LAN¡¢DI/DOµÈ LED ¿´ÃŹ·¶¨Ê±Æ÷1·£¨¿É±à³Ì£© »·¾³ ʪ¶È 95% @ 40¡ã C£¨·ÇÄý½á£© ¹¤×÷ÎÂ¶È 0 ~ 45¡ã C @ 5 ~ 85%RH ¶©»õÐÅÏ¢ UNO-2679COM-C11E C-M 1.0 G, 512 MB RAM×Ô¶¯»¯µçÄÔ Åä¼þ 1701440151 IDEÓ²ÅÌÏß 1960014827N000 2.5¡±Ó²ÅÌ¼Ü PCLS-DIAGAW10 DiagAnywhereÔ¶³Ìά»¤Èí¼þ
UNO-3072LA ÑлªUNO-3072LA Intel®Atom™´ø2*PCI£¬2*ǧÕ×ÒÔÌ«Íø£¬2*COM»úе×Ô¶¯»¯¿ØÖÆÆ÷ ¸ÅÊö UNO-3072LAÊÇÒ»¿î»ùÓÚAtomÁ趯´¦ÀíÆ÷µÄǶÈëʽ¹¤Òµ¼¶¿ØÖÆÆ÷£¬´øÓÐ2¸öPCI²å²Û£¬¾ß±¸×¿Ô½µÄµÍ¹¦ºÄÆ·ÖÊ¡£Ç§Õ×LANÖ§³Ö·Ö×éÈÝ´í¹¦ÄÜ£¬Á´Â·¾ÛºÏºÍ¸ºÔØƽºâ¡£ÓëÒ»°ãµÄ¹¤ÒµµçÄÔ²»Í¬£¬UNO-3072LAµÄÎÞ·çÉÈ¡¢ÎÞ½ÓÏßÉè¼ÆʹÆä½á¹¹¸ü¼Ó½ô´Õ£¬±íÏÖ¸ü¼Ó¿É¿¿¡£¿ª·Åʽƽ̨Äܹ»Âú×㹤ҵÏÖ³¡µÄ²»Í¬ÒªÇó£¬Ê¹Æä³ÉΪ¹¤Òµ×Ô¶¯»¯¿ØÖƵÄÀíÏë½â¾ö·½°¸¡£UNO-3072LAÖ§³ÖWindows XP Embedded OS£¬´øÓÐÓÅ»¯¹ýµÄ°åÔØÉ豸Çý¶¯³ÌÐò£¬Äܹ»Ìṩ¶¨ÖƵÄÓ³ÏñÎļþ£¬Ç¶ÈëʽWindows XPÄܹ»ÒÔ×é¼þ·½Ê½ÌṩǶÈëʽWindows²Ù×÷ϵͳµÄ¹¦ÄÜ¡£ ÌØÐÔ °åÉϼ¯³ÉAtom N270 1.6 GHz´¦ÀíÆ÷ 2¸öRS-232/422/485¶Ë¿Ú£¬´ø×Ô¶¯Êý¾ÝÁ÷¿ØÖÆ 2¸ö10/100/1000 Base-T RJ-45¶Ë¿Ú£¬Ö§³Ö·Ö×鹦ÄÜ 2¸öPCI²å²ÛÂú×㲻ͬӦÓà ֧³ÖWindows® 2000/XP/VistaºÍǶÈëʽLinux °åÔØʽϵͳ£¬I/O´®¿Ú¼°LEDָʾµÆ Ö§³ÖLAN»½ÐѺÍLANÆô¶¯¹¦ÄÜ Ö§³ÖÒôƵÏß·Êä³ö¹¦ÄÜ ¼ò½àµÄÎÞ·çÉÈÉè¼Æ£¬ÄÚ²¿ÎÞ½ÓÏß µ×°åÓëµçÔ´½ÓµØ¼ä×°ÓиôÀë±£»¤ AT/ATXµçԴģʽ¿Éͨ¹ýÌøÏßÑ¡Ôñ ¿É±à³ÌLED I/OÇ°³öÏßÉè¼Æ ¿í²Ù×÷ζȣº-10 ~ 60¡ã C 1¸öÄÚÖÃUSB£¬¿ÉÁ¬½Ó¼ÓÃܹ·»òUÅÌ
UNO-3074 ÑлªUNO-3074 Intel® Pentium® M´ø4xPCI²å²Û£¬1xPC¿¨²å²ÛǶÈëʽ¹¤Òµ¼¶¿ØÖÆÆ÷ ¸ÅÊö ÑлªUNO-3074ϵÁÐÊǸßÐÔÄܵÄPentium M/Celeron M¼¶Ç¶Èëʽ¹¤Òµ¼¶¿ØÖÆÆ÷£¬²¢´øÓÐ4¸öPCIÀ©Õ¹²Û¡£UNO-3074²ÉÓÃÁ˼á¹ÌµÄÉè¼Æ£¬Ìṩ˫µçÔ´ÊäÈëºÍµç³Ø±¸·ÝSRAM¡£ÓëÒ»°ã¹¤ÒµPC²»Í¬, UNO-3074¸ü¼Ó½ô´ÕºÍ¿É¿¿¡£ÕâÊÇÒ»¸öÄÜÂú×ãÈκι¤ÒµÏÖ³¡Ó¦ÓÃÐèÇóµÄ¿ª·Åƽ̨£¬Êǹ¤Òµ×Ô¶¯»¯ºÍ¿ØÖÆÓ¦ÓõÄÀíÏë½â¾ö·½°¸¡£UNO-3074Å䱸ǶÈëʽ²Ù×÷ϵͳ£¬¸Ã²Ù×÷ϵͳÌṩ¶¨ÖƵÄÓ³ÏñÎļþ£¬´øÓÐÓÅ»¯¹ýµÄ°åÔØÉ豸Çý¶¯³ÌÐò¡£Ö§³ÖWindows XP EmbeddedǶÈëʽ²Ù×÷ϵͳÄܹ»ºÜºÃµÄÂú×ãÓû§¶ÔÓÚÍêÕû¹¦ÄÜ¡¢¸ß¿É¿¿ÐÔµÄÓ¦ÓÃÐèÇó¡£ ÌØÐÔ Éϼ¯³ÉPentium® M»òCeleron® M´¦ÀíÆ÷ Ìṩ512 KBµç³Ø±¸·ÝSRAM 2¸öRS-232ºÍ2¸öRS-232/422/485¶Ë¿Ú£¬´øRS-485×Ô¶¯Êý¾ÝÁ÷¿ØÖÆ 2¸ö10/100Base-T RJ-45¶Ë¿ÚºÍ4¸öUSB¶Ë¿Ú 4¸öÊÊÓÃÓÚ¶àÖÖÓ¦ÓõÄPCI×ÜÏßÀ©Õ¹²Û ¹¤ÒµÉè¼Æ£¬50G¿¹³å»÷ÐÔÄÜ£¬2G¿¹Õñ¶¯ÐÔÄÜ 4·¸ôÀëDI£¬4·¸ôÀëDO£¬´ø¶¨Ê±Æ÷¡¢¼ÆÊýÆ÷ºÍÖжϴ¦Àí Ö§³ÖË«µçÔ´ÊäÈëlWindows® 2000/XPÇý¶¯¼´ÓúÍLinuxÇý¶¯Ö§³Ö ´øд±£»¤£¨EWF£©µÄWindows XP (SP2) Embedded¼´ÓÃƽ̨ ǶÈëʽLinux¼´Óýâ¾ö·½°¸ ¹æ¸ñ Ò»°ã¹æ¸ñ ÈÏÖ¤ CE, FCC class A ³ß´ç(W¡ÁD¡ÁH) 180¡Á237¡Á177 mm (7.1"¡Á9.3"¡Á7.0") Íâ¿Ç ÂÁÖÊÍâ¿Ç°²×°£¨¿ÉÑ¡£© ±Ú¹Òʽ/Ãæ°å/±ê×¼°²×° ¹¦ºÄ 24 W£¨µäÐÍ£¬ÎÞPCI¿¨£© µçÔ´ÊäÈë 20 ~ 36 VDC (Èç+24 V @ 4 A) (×îС96 W), AT ¾»ÖØ 5.0 kg OSÖ§³Ö Windows XP embedded, Windows 2000/XP,WinCE 5.0, Linux ϵͳӲ¼þ CPU Celeron M 1.0 GHz »ò Pentium M 1.4 GHz ÄÚ´æ 512 MB DDR SDRAM µç³Ø±¸·ÝRAM 512 KB À©Õ¹²Û 4¡ÁPCI V 2.2 (×¢Ò⣺PCI¿¨ÖеÄÉ¢ÈÈ»áÓ°ÏìÈÈÐÔÄÜ£© ָʾµÆ ÌṩµçÔ´¡¢µçÔ´ÊäÈë1¡¢µçÔ´ÊäÈë2¡¢µçÔ´¹ÊÕÏ¡¢IDE¡¢Õï¶Ï¡¢4COM¶Ë¿ÚTx/RxºÍµç³Ø±¸·Ý ±¨¾¯µÄLEDָʾµÆ¡£¿É±à³Ì·äÃùÆ÷¡£¼üÅÌ/Êó±ê 1¡ÁPS/2 PC¿¨ 1¡ÁPC¿¨²å²Û£¬Ö§³ÖCardBus (Card-32)¿¨£¬16λ(PCMCIA 2.1/JEIDA4.2)¿¨Ö§³Ö+5 V¡¢+3.3VºÍ+12 V @ 120 mA ¹¤×÷µçÔ´PCI²å²ÛµçÔ´ 12 V @ 5 A, -12 V @ 0.8 A, +5 V @ 8 A,+3.3V@ 6A´æ´¢¹Ì̬µç×ÓÅÌ1¡ÁÄÚÖÃType I/II CompactFlash® ²å²Û 1¡ÁÍâÖÃType I/II CompactFlash® ²å²Û Ó²ÅÌ ÄÚÖÃÓ²ÅÌÍмܣ¬ÓÃÓÚ°²×°Ò»¸ö±ê×¼2.5"Ó²ÅÌ VGA DB15 VGA½Ó¿Ú£¬Ö§³ÖCRTģʽ£º1600 x 1200@ 85 Hz¿´ÃŹ·¶¨Ê±Æ÷ ¿É±à³Ì ͨѶ ʱÖÓ ÓÃÓÚʱ¼äºÍÈÕÆڵĵç³Ø±¸·ÝRTC LAN 2¡Á10/100Base-T RJ-45¶Ë¿Ú ´®¿Ú 2¡ÁRS-232, 2¡ÁRS-232/422/485£¬´øDB9½Ó¿Ú£¬×Ô¶¯RS-485Êý¾ÝÁ÷¿ØÖÆ ´®¿ÚËÙ¶È RS-232: 50 bps ~ 115.2 kbpsRS-422/485: 50 bps ~ 921.6 kbps (×î´ó) USB¶Ë¿Ú 4¡ÁUSB£¬·ûºÏUSB UHCI, Rev. 2.0±êÊý×ÖÁ¿ÊäÈë(4·ʪ½ÓµãDI0~DI3) 2,000 VDC¸ôÀë--50 ~ 70 VDC ¹ýѹ±£»¤ ¡À50 VDCÊäÈ뷶ΧºÍ10 kHzËÙ¶È Öжϴ¦ÀíËٶȣº10 kHz Êý×ÖÁ¿Êä³ö(4·DO0~DO3) 2,000 VDC ¸ôÀë±£»¤¼°200 mA ×î´óͨµÀ»ãµçÁ÷ϵͳÈÈÆô¶¯ºó±£³ÖÊä³ö״̬ 0 ~ 40 VDCÊä³ö·¶Î§ºÍ10 kHzËÙ¶È ¼ÆÊýÆ÷/¶¨Ê±Æ÷ (2¡Á16λ) ¼ÆÊýÔ´£ºDI1 & DI3£¬Âö³åÊä³ö£ºDO2 & DO3¿É¼¶ÁªÎ»Ò»¸ö32λ¼ÆÊýÆ÷/¶¨Ê±Æ÷ ¼õ¼ÆÊý£¬Ô¤Éè¼ÆÊýֵʱ»ù£º100 kHz, 10 kHz, 1 kHz, 100 Hz »·¾³ ʪ¶È 95% @ 40¡ãC (ÎÞÄý½á) ¹¤×÷ÎÂ¶È -20 ~ 55¡ãC (-4 ~ 131¡ãF) @ 5 ~ 85% RH ³å»÷±£»¤ IEC 68 2-27 CompactFlash£º50 G @ ±Ú¹Òʽ°²×°£¬°ëÕýÏÒ²¨£¬11ºÁÃëÓ²ÅÌ£º20 G @±Ú¹Òʽ°²×°£¬°ëÕýÏÒ²¨£¬11ºÁÃëÕñ¶¯±£»¤ IEC 68 2-64 (Ëæ»ú1 Oct./·ÖÖÓ, 1Сʱ/Öá.)CompactFlash£º2 Grms @ 5 ~ 500 Hz Ó²ÅÌ£º1 Grms @ 5 ~ 500 Hz
UNO-3082/UNO-3084 ÑлªUNO-3082/UNO-3084 Intel Core 2 Ë«ºË´¦ÀíÆ÷,´øË«DVI,2xPCIIEEE1394½Ó¿Ú×Ô¶¯»¯Ç¶Èëʽ¿ØÖÆÆ÷£¬ ¸ÅÊö UNO-3082/3084ÊÇÒ»¿î¸ßÐÔÄÜǶÈëʽ¹¤Òµ¼¶¿ØÖÆÆ÷£¬×î¶à¿ÉÖ§³Ö4¸öPCIÀ©Õ¹²Û¡£UNO-3082/3084ÉϵÄǧÕ×LANÖ§³Ö·Ö×éÈÝ´í¹¦ÄÜ£¬Á´Â·¾ÛºÏºÍ¸ºÔØƽºâ¡£Í¬Ê±ÅäÓÐ2¸öIEEE 1394b½Ó¿Ú£¬·½±ãÓû§Á¬½Ó»úеÊÓ¾õÓ¦ÓÃÉ豸¡£ÖØÒªÊý¾Ý¿É±»´¢´æÔÚUNO-3082/3084µÄµç³Ø±¸·ÝSRAMÖС£UNO-3082/3084Ö§³ÖRAID0/1£¬´øÓÐ2¸öHDDÍмܡ£ ÌØÐÔ °åÔØ Core 2 L7500 1.6 GHzË«ºË´¦ÀíÆ÷ Ë«DVI-I ×î¶àÖ§³ÖÁ¬½Ó3̨ÏÔʾÆ÷ Ë«IEEE-1394£¬Ö§³ÖÁ¬½ÓÊÓ¾õ¼ì²â×°Öà AT/ATXµçԴģʽ¿Éͨ¹ýÌøÏßÑ¡Ôñ °åÔØ 512KB µç³Ø±¸·Ý SRAM 2¸öRS-232/422/485 ¶Ë¿Ú£¬´ø×Ô¶¯Êý¾ÝÁ÷¿ØÖÆ 2¸ö10/100/ 1000 Base-T RJ-45 ¶Ë¿Ú£¬Ö§³Ö·Ö×鹦ÄÜ ×î¶àÖ§³Ö3¸öPCI ºÍ1¸ö PCIeÀ©Õ¹ 4ͨµÀ¸ôÀëÊý×ÖI/O Ë«SSD/HDD £¬Ö§³Ö°åÔØ RAID 0/1 ÎÞ·çÉÈÉè¼Æ£¬ÎÞÄÚ²¿½ÓÏß µ×°åÓëµçÔ´½ÓµØ¼ä×°ÓиôÀë±£»¤ Ç°³öÏßÉè¼Æ 1¸öÄÚÖÃUSB£¬¿ÉÁ¬½Ó¼ÓÃܹ·»òUÅÌ UNO-4679 ÑлªUNO-4679 Celeron® M 1GHz£¬Ö§³Ö½»Ö±Á÷Á½ÓõçÔ´£¬´ø5xLAN£¬4xUSB£¬2xRS-232£¬4x¹â¸ôÀëRS232/422/485£¬8xDI£¬8xDO,1x²¢¿Ú£¬1xPC/104À©Õ¹ÎÞ·çÉÈǶÈëʽ¿ØÖÆÆ÷ ¸ÅÊö UNO-4679ÊÇÒ»¿î¸ßÐÔÄÜÎÞ·çÉÈͨÓÃÍøÂç¿ØÖÆÆ÷£¬Ö§³Ö´®ÐÐͨÐŶ˿ڡ¢ÒÔÌ«ÍøÒÔ¼°Êý×ÖÁ¿ÊäÈëÊä³ö¹¦ÄÜ£¬ÒÔ¼°½»Á÷£¨100 ~ 240 VAC£©»òÖ±Á÷£¨100 ~240 VDC£©¡¢Ö±Á÷£¨10 ~ 30 VDC£©ÊäÈë¡£UNO-4679COMB´øÓÐ5¸öLAN¡¢4¸öUSB (1¸öÄÚ²¿)¡¢2¸ö±ê×¼RS-232C¡¢4¸öRS-232C/422/485£¨¿ÉÉ趨¡¢¸ôÀ룩¡¢8¸ö¸ôÀëÊý×ÖÁ¿ÊäÈëºÍ8¸ö¸ôÀëÊý×ÖÁ¿Êä³öµÈ½Ó¿Ú£¬Ö§³ÖWindows XP Embedded¡¢Windows CE.NETºÍLinux£¬Äܹ»Ìṩ¿É¶¨ÖÆÓ³ÏñÎļþ£¬´øÓÐÓÅ»¯°åÔØÉ豸Çý¶¯³ÌÐò£¬ÒÔÂú×㲻ͬµÄÓ¦ÓÃÐèÇó¡£ ÌØÐÔ °åÉϼ¯³ÉIntel® Celeron® M 1 GHz´¦ÀíÆ÷ ˫·µçÔ´£º100 ~ 240 VAC»ò100 ~ 240 VDC£¬10 ~ 30 VDC 2¸öRS-232ºÍ4¸öRS-232/422/485¶Ë¿Ú£¨¿É¸ôÀë¡¢É趨£©, RS-485´ø×Ô¶¯Êý¾ÝÁ÷¿ØÖÆ 8·¸ôÀëDI£¬8·¸ôÀëDO 1·²¢¿Ú 5¸ö10/100 Base-T RJ-45¶Ë¿Ú 4¸öUSBºÍ1¸öType¢ñ/¢ò CF¿¨²å²Û Windows® CE¡¢Windows® XP EmbeddedºÍLinux½â¾ö·½°¸ ¹æ¸ñ Ò»°ã¹æ¸ñ ³ß´ç 440 ¡Á 271.5 ¡Á 89 mm Íâ¿Ç SECC½ðÊôÍâ¿Ç °²×° 2U 19¡±»ú¼Ü°²×° ¹¦ºÄ24W£¨µäÐÍ£© ¾»ÖØ5.5 kg µçÔ´ÊäÈ뷶Χ 10 ~ 30 VDC¡¢100 ~ 240 VDC¡¢100 ~ 240 VAC OSÖ§³Ö Windows CE.NET¡¢Windows XPEmbedded¡¢Windows XP¡¢Linux ϵͳÉè¼Æ ÎÞ·çÉÈϵͳÉè¼Æ ϵͳӲ¼þ CPU Celeron®M 1GHz ÄÚ´æDDR SODIMM 512MÏÔʾDB-15VGAÁ¬½Ó£¬1600¡Á1200 @ 85 Hz ¼üÅÌ&Êó±ê PS/2½Ó¿Ú ´æ´¢ 1 x ÄÚÖÃType¢ñ/¢òCompact Flash¿¨²Û 1 x ÄÚÖÃSATAÓ²Å̽ӿںÍ2.5¡±Ó²ÅÌÖ§¼Ü 8·¸ôÀëÊý×ÖÊäÈë ͨµÀ 8 ¸ôÀë±£»¤ 2000 VDC ¹ýѹ±£»¤ 50 VDC ÊäÈ뷶Χ 0 ~ 30 VDC ÊäÈëµçѹ Âß¼0£º0 ~ 3 VDC£»Âß¼1£º5 ~ 30 VDC ÊäÈëµçÁ÷ 10 VDC @ 2.5 mA¡¢12 VDC @ 3.1 mA¡¢24 VDC @ 6.5 mA 8·¸ôÀëÊý×ÖÊä³ö ͨµÀ 8 ¸ôÀë±£»¤ 2000 VDC Êä³ö·¶Î§ 5 ~ 40 VDC ͨѶ ´®¿Ú 2 ¡Á ±ê×¼RS-232ºÍ4 ¡Á ¸ôÀëRS-232/422/485¶Ë¿Ú ´®¿ÚËÙ¶È ×î´ó115.2 kbps LAN 5 ¡Á 10/100 Base-T RJ-45¶Ë¿Ú USB½Ó¿Ú 4·¼æÈÝUSB2.0 ָʾµÆ µçÔ´¡¢IDE¡¢Í¨Ñ¶Tx/Rx¼ì²â¡¢LAN¡¢DI/DOµÈ LED ¿´ÃŹ·¶¨Ê±Æ÷ 1·£¨¿É±à³Ì£© »·¾³ ʪ¶È 95% @ 40¡ã C£¨·ÇÄý½á£© ¹¤×÷ÎÂ¶È 0 ~ 50¡ã C @ 5 ~ 85%RH ¶©»õÐÅÏ¢ UNO-4679COMB-C11E C-M 1.0 G, 512 MB RAM×Ô¶¯»¯µçÄÔ Åä¼þ PCLS-DIAGAW10 DiagAnywhereÔ¶³Ìά»¤Èí¼þ
