¼ò½é
WE-2100TÊÇÒ»¿î½ô´ÕÐÍÄÚǶʽÎÞÏßÁªÍøÄ£¿é²¢¿ÉÒÔʵÏÖÊý¾ÝµÄ°²È«´«Êä¡£¸Ã²úÆ·¿ÉÒÔ½«´®¿ÚÉ豸Á¬½Óµ½ÎÞÏß½ÓÈëµã£¬»òÓëÁíÍâһ̨WE-2100TʵÏֵ㠶ԵãÁ¬½Ó¡£½èÖúWE-2100T£¬Óû§ÎÞÐèÁ˽⸴ÔÓµÄÎÞÏß¼¼Êõ±ã¿ÉÇáËÉʵÏÖ´®¿ÚÉ豸µ½ÎÞÏßÒÔÌ«ÍøµÄÁ¬½Ó¡£´ËÍ⣬¸Ã²úÆ·»¹·ûºÏ802.11a/b/gÎÞÏß±ê ×¼£¬¿É¶ÔÊý¾Ý´«Êä½øÐмÓÃÜ¡£
ΪÄÚǶʽӦÓÃÉè¼ÆµÄ²Ù×÷ģʽ
WE-2100TÖ§³ÖReal COM£¬TCP Server£¬TCP Client£¬UDPºÍRFC2217²Ù×÷ģʽ¡£ÕâЩ²Ù×÷ģʽÊÇΪÂú×ãÄÚǶʽӦÓõÄÒªÇó¶øÉè¼ÆµÄ¡£²úÆ·Ö§³Ö¸÷ÖÖ²Ù×÷ϵͳµÄReal COMÇý¶¯³ÌÐò£¬°²×°¼òµ¥¡£
²ÉÓÃSerial CommandģʽÔÚÏÖ³¡½øÐÐÅäÖÃ
- ¿ÉÒÔÔÚÏÖ³¡ÇáËÉʵÏÖÍøÂç²ÎÊýÅäÖÃ
- ÃüÁî¸ñʽ¼òµ¥
- ´®¿Ú¡¢ÍøÂçÅäÖÃÃüÁîÊ®·Ö¼òµ¥
- ÇáËÉÇл»Èí¡¢Ó²¼þ´¥·¢
- ͨ¹ýÈí¼þʵÏÖÖØÆô
Ìصã
- ½«´®¿ÚÉ豸Á¬½Óµ½IEEE802.11a/b/gÎÞÏßÍøÂç
- Ö§³ÖReal COM£¬TCP Server£¬TCP Slave£¬UDPºÍ
- RFC2217²Ù×÷ģʽ
- Ö§³ÖWindows£¬Linux COMÇý¶¯
- Ö§³ÖWindows Vista Real COMÇý¶¯
- ²ÉÓÃWEP£¬WPAºÍWPA2½øÐÐÎÞÏßÊý¾Ý¼ÓÃÜ
- ͨ¹ý´®¿Ú²ÉÓô®¿ÚÃüÁî½øÐÐÅäÖÃ
- Ö§³Ö·Ç±ê×¼²¨ÌØÂÊ£¬Èç250 KºÍ500 K
- 8¸ö¿ÉÓÃÓÚ±à³ÌµÄDI/DOͨµÀ
- ͨ¹ýSSL/SSH½øÐмÓÃÜÅäÖÃ
- ½á¹¹½ô´Õ£¬Ò×ÓÚ°²×°
WLAN ¼æÈݱê×¼£ºIEEE802.11 a/b/g
չƵ¼¼Êõ£ºDSSS£¬CCK£¬OFDM
±£»¤£ºÄÚ½¨1.5 KVµç´Å¸ôÀë±£»¤
Tx¹¦ÂÊ£º
5.15 ~ 5.35 GHz£º 15 dBm @ 6 Mbps£»12 dBm @ 54 Mbps
5.725 ~ 5.825 GHz£º 15 dBm @ 6 Mbps£»12 dBm @ 54 Mbps
2.412 ~ 2.483 GHz£º 17 dBm @ 6 Mbps£»15 dBm @ 54 Mbps
2.412 ~ 2.472 GHz£º 18 dBm @ 1 to 11 Mbps
RxÁéÃô¶È£º
5.15 ~ 5.35 GHz£º 6 Mbps @ -90 dBm£»54 Mbps @ -72 dBm
5.725 ~ 5.825 GHz£º 6 Mbps @ -89 dBm£»54 Mbps @ -72 dBm
2.412 ~ 2.483 GHz£º 6 Mbps @ -90 dBm£»54 Mbps @ -73 dBm
2.412 ~ 2.472 GHz£º 11 Mbps @ -87 dBm£»1 Mbps @ -94 dBm
´«ÊäËÙÂÊ£º
802.11a£º54 Mbps
802.11b£º11 Mbps
802.11g£º54 Mbps
´«Êä¾àÀ룺³¤´ï100 Ã×
¼ÓÃÜ»úÖÆ£ºAES£¬WEP 64/128-bit£¬WPA£¬WPA2£¬802.11i
802.11iÈÏÖ¤»úÖÆ£º
PEAP£¬EAP-TLS£¬EAP-TTLS£¬PEAP/MSCHAPv2£¬
PEAP/TLS£¬PEAP/GTC£¬PEAP/MD5£¬EAP-TTLS/EAPMD5£¬
EAP-TTLS/EAP-GTC£¬EAP-TTLS£¬EAP-TTLS/
EAP-MSCHAPv2£¬EAP-TTLS/EAP-TLS£¬EAP-TTLS/
MSCHAPv2£¬EAP-TTLS/MSCHAP
ƵµÀ£º
±±ÃÀ£ºCH1 ~ CH11£¬5150-5825 MHz
Å·ÖÞ£ºCH1 ~ CH13£¬5150-5875 MHz
ÈÕ±¾£ºCH1 ~ CH14£¬5150-5350 MHz
ÌìÏßÁ¬½ÓÆ÷£ºReverse SMA
ÍøÂç½ÓÈëģʽ£ºInfrastructure mode (a/b/g)£¬Ad-Hoc mode (b/g)
´®¿Ú ¶Ë¿ÚÊýÁ¿£º1
ÐźÅÀàÐÍ£ºTTL
´®¿ÚͨÐŲÎÊý УÑéλ£ºNone£¬Even£¬Odd£¬Space£¬Mark
Êý¾Ýλ£º5£¬6£¬7£¬8
ֹͣλ£º1£¬1.5£¬2
Á÷Á¿¿ØÖÆ£ºRTS/CTS£¬XON/XOFF£¬DTR/DSR
ͨÐÅËÙÂÊ£º50 ~ 921.6 Kbps (±ê×¼²¨ÌØÂÊ)£¬250ºÍ500 Kbps
(ÌØÊⲨÌØÂÊ)
Èí¼þÌصã ÐÒ飺ICMP£¬IP£¬TCP£¬UDP£¬DHCP£¬Telnet£¬DNS£¬SNMP£¬
HTTP£¬SMTP£¬SNTP£¬SSH£¬HTTPS
Ó¦ÓóÌÐò£ºÓÃÓÚWindows 98/ME/2000/XP/2003/VistaµÄ
Windows utility
Ö§³ÖµÄ²Ù×÷ϵͳÇý¶¯³ÌÐò£ºWindows 95/98/ME/NT/2000/
XP /2003/XP x64/2003 x64/Vista COM driver£¬Linux Real
TTY driver£¬SCO Unix£¬SCO OpenServer 5£¬UnixWare 7£¬
UnixWare 2.1.x£¬SVR4.2£¬QNX
ÅäÖ÷½Ê½£ºWeb console£¬serial console£¬Telnet console»ò
Windows utility
µçÔ´ÒªÇó µçÔ´ÊäÈ룺3.3V ¡À 5%
µçÔ´¹¦ºÄ£º950 mA @ 3.3V
»·¾³²ÎÊý ¹¤×÷ζȣº0 ~ 55 ¡ãC (32 ~ 131 ¡ãF)£¬5 ~ 95% RH
´æ´¢Î¶ȣº-20 ~ 85 ¡ãC (-4 ~ 185 ¡ãF)£¬5 ~ 95% RH
