isee-
浩亭宣布其欧洲配送中心落成
http://www.gkong.com 2019-07-09 15:30 《中华工控网》翻译
HARTING announces innauguration of European Distribution Center
浩亭宣布其欧洲配送中心落成
July 3, 2019 --- A day of festivity marked the HARTING Technology Group's official inauguration of its European Distribution Center (EDC) in Espelkamp. Costing an estimated € 45 million, the EDC logistics center is the largest single investment in the 74-year history of HARTING.
2019年7月3日--- 浩亭技术集团举行了一天的庆祝活动,作为其在埃斯珀尔坎普(Espelkamp)欧洲配送中心(EDC)的正式落成典礼。该配送中心是浩亭74年历史上最大的单笔投资,耗资大约4500万欧元。
1
Roughly 10,000 packages can be shipped to customers and branches around the world on a daily basis. The 20-meter-high shelf warehouse can accommodate approx. 7,000 pallets and 120,000 containers. Installation work involved laying 100 kilometres of IT cabling, 40 kilometers of sprinkler piping and container conveyor technology with a total length of 1,000 meters. 2,000 containers can be taken in and out of the warehouse every hour. Technical highlights include the automated picking system and the storage area, which is managed and utilized according to the respective order load and capacity. RFID technology ensures that pallets are correctly placed and loaded.  A driverless transport system is responsible for transporting the goods between the halls and independently selects the optimum route. The flexible logistics of the EDC also enable a fast response to changed economic or political framework conditions such as trade barriers, for instance.
在该配送中心,每天大约有10,000个包裹可以运送到世界各地的客户和分支机构。20米高的货架仓库可容纳约7,000个托盘和120,000个集装箱。安装工作涉及铺设100公里的IT布线,40公里的喷水管道和总长1000米的集装箱运输技术。每小时可以进出仓库2000个集装箱。技术亮点包括自动提货系统和存储区,根据各自的订单负载和产能进行管理和利用。射频识别技术确保托盘被正确放置和装载。无人驾驶运输系统负责在大厅之间运输货物,并独立选择最佳路线。该中心灵活的物流也能对多变的经济或政治框架条件作出快速反应,例如贸易壁垒。
Great emphasis was also placed on generating a sustainable energy supply. The power for the European Distribution Center is supplied by a photovoltaic system installed on the roof, while the energy requirements for cooling and heating are covered by internally produced biomethane and a geothermal plant – for which 36 holes needed to be drilled to a depth of 150m. The implemented energy concept minimises the Co2 emissions. The cost of the entire center came in 27 percent lower than the figure originally calculated by the Kreditanstalt für Wiederaufbau (KfW). 140 employees work in the logistics center in a two-shift system.
该中心还非常重视产生可持续的能源供应。欧洲配送中心的电力由安装在屋顶上的光伏系统提供,而冷却和加热所需的能源由内部生产的生物甲烷和地热工厂提供——为此需要钻36个深度为150米的孔。实施的能源概念最大限度地减少了二氧化碳排放。整个中心的成本比最初由德国再建设银行计算的数字低27%。该物流中心有140名员工,实行两班制工作。
The offices and social spaces, reception, bistro with terrace and seating areas are all bright and friendly. With its white facade, the EDC is visible on its 8-hectare site on the L 770 in northwest Eselkamp.
办公室和社交空间、接待处、带露台的小酒馆和座位区都明亮友好。该中心有着白色外面,地址位于埃斯珀尔坎普西北面的L 770,占地8公顷。
